FuriousDz
Hey Guys, so Im having some front end issues with death wobble.
Most of the time its fine but certain railroad tracks and bumps will get it going.
So I crawled under to have a look and make sure everything was tight then had someone move the sterring wheel back and fourth to see what moved.
Track bar looks good but there is some play in my tie rod ends and even some in the drag link.
Since Im not comfortable assesing this myself I took it to the shop that installed the lift and they pretty much confirmed its an ball joint issue.
They said they would put the synergey tie rod and high steer drag link in to fix the issue.
So my question is, is 40k too soon for these to fail? and if so is their solution the right way to go?
Im running 37 toyo's on 1.5 spacers for the past 10k
before that it was 35 nitto trail grapplers withOUT spacers for about 25k.
Thanks
Mike
Thanks
Mike
