ATX Slab question
mackey
I just got my slabs from brown Santa. I want to paint or powder coat the rings black. Any suggestions or tips if I spray paint them? Do I need to use an etching primer? Anyone done this, or should I get them powder coated. Thanks for the help.
I'd probably just rattle can them with a matching satin black. You will have to touch them up often so you might as well do it with something inexpensive and easy.
I painted mine with VHT Satin Black wheel paint, it matches perfect. For prep I just sanded the rings 220 grit and then wiped them down with acetone before paint.
Don't powder coat. I used VHT satin black wheel paint. It matches perfectly. You can prime them but I wouldn't put too much effort into it. They get scuffed up on rocks anyway
