mcpuck
:thumbdown: well I guess I will stick with just unbolting my links and throwing them in the back...
andrew-
Andrew, this is the REAR sway bar I am referring to.
andrew-
This is true, but you still have taken up cargo space inside the cab that an EVO Lever doesn't![]()
So like I always do I cruise around EVO website looking at the things I want to buy. Then I came across the EVO Lever Rear Coil Over System. It says it can work with any lift but how does this work?
http://www.offroadevolution.com/store/proddetail.php?prod=EVO-LEVER
I don't think I have ever seen a lever setup on a 2 door :thinking:
You always cruise around their site but you just stumbled on EvoLever? You might want to stumble on the double throwdown version before you jump on the evolever.
EVO lever is for the rear, DTD is for the front.
not quite. i believe there is add-ons that is considered dtd rear?
Ah yeah your right. It has the bypass whereas the lever doesn't.
like mine!
like mine!
I haven't looked at the lifts since I have a long arm kit already. I've been more looking into suspension and droop.
How is the on road handling? Does that much flex cause problems turning at speed or making tight turns at speed?
