(my lack off knowledge is about to show) where is the adjucting clamp located so i can take a look
It's on the draglink. Look for a turnbuckle with two bolts on it. :thumb:
Here you go: http://wayalife.com/showthread.php?...nt-End-Alignment&p=42376&viewfull=1#post42376
Wish you would've said something while we were at Rausch we coulda checked it for you. Every one has to learn some how, we could have at least eliminated a few things.
Sent from my SPH-L720
Was just about to ask the same question. Also this reminds me I gotta do an alignment. My rear end is off by 5mm and I still need to center my steering wheel lol
Is your tc light coming on?
All the bolts are nice and tight but the rod/shaft it's self can be rotated up and down. This normal
Yes its normal. thats the movement at the joint and necessary for the steering range of motion as the pitman arm rotates back and forth and as that axle articulates.
Did tightening the bolts help resolve your issue? Also inspect the body and yoke of your pitman arm where it attaches to the draglink. Its not common, but it is a distant POSSIBILITY that it could be cracked/broken and cause your steering the jump teeth and be off center and then back centered.
your pic edited in case I didnt explain clearly
thanks for all the responses everyone! yes it did go off ten mins into my drive this weekend.
another question that kind of goes along with this. so i had it straightened thursday and first thing saturday morning before i even hit the trails i hit a little bump and it was off center again. later that day im on my way home hit another bump and its straight again. what would cause my steering wheel to keep going off center like that then back in line? did the shop that did my alignment over torque something to cause this to happen multiple times? do i just need a new tie rod?
Well it's centered now. Shouldn't take long for the computer to realize this I'm assuming. Thanks for confirming this Eddie!
Sent from my iPhone
Thanks Chris you explained clearly but I'm a visual person so the pic was extremely helpful. I will look at it today. Tightening the bolts did not resolve my issue sadly. It has me really worried that its doing this.
I am an idiot and noticed that I was typing quick and didnt give all the intended info. The pitman arm teeth that could be jumping is at the sector shaft end...and meant to say to look at that end of the pitman arm first. I edited my post.
Really sounds like a loose track bar end as mentioned. It doesn't take much but if the bolt hole is ovalled a bump would move the axle even if the bolt was tight.
