Well thanks for that nightmare LOL I hope it's not that bad but this being the second auxiliary battery and soon to be the third in less than a year I wish there was a way to completely take out the start stop starter and just eliminate that whole fucking systemHaven't posted about it but my daughters JL (Badger) has been in the shop for 2-1/2 months with an unsolvable electrical issue. Donated to the dealership retirement fund twice - $1400 once & $800 and was assured it as fixed. Went to pick it up the second time and it had the exact same issue. I picked it up with my trailer out of their lot and took it t the shop that built Gruff. He's stumped & consulting electrical gurus to no avail.
Was getting the start/stop message - I thought it was the batteries and changed both - didn't do anything. Next issue was the Christmas light effect. Last time I attempted to drive it the fucking power steering went totally out & I almost drove off the road going around a sharp corner. Anyone else had that happen? It's 100% worse than a manual steering vehicle - it's like trying to turn the steering wheel with the engine off. And then we finished the act by not even allowing me even shift it out of park. So it's sitting. I'd consider telling her to dump it but it's stuck.
Just had that same msg on mine. Put a code reader on it and no codes. Tested batteries and determined that was the issue. Replaced both batteries and problem solved.On the road, start stop first indicated battery charging and was actually operational once the battery fully charged and now after 150 MI I've got this warning
Anyone come across this?
I’d drive it… lol
Me too!I’d drive it… lol
It’s trueThe most perfect practical un-cool vehicle ever. Embrace it.
that's what I'm hoping, both batteries are under warranty and will get replaced tomorrow or tuesdayJust had that same msg on mine. Put a code reader on it and no codes. Tested batteries and determined that was the issue. Replaced both batteries and problem solved.
Family of five and we avoided it. That’s what Sierra Cadillacs (Yukon XL) are for.It’s true
lol can’t argue thereFamily of five and we avoided it. That’s what Sierra Cadillacs (Yukon XL) are for.
I forget about that bus bar, my issue happens every time I take bumps too hard or in the last case, hit a chuckhole in NM at 70mph. Once it's had time to reset, everything is back to normal, that last time it took over a month.Followup for my issue: Took to a new dealer and they scanned it, found 5 outstanding TSB's that evidently the dealer by me was too retarded to check for, or just ignored. One of the TSB's was for the bus bars behind the glove box. Ordered in and installed the next day and we're back in business.
What should have been fixed in June took the entire Summer of it bouncing around. Fuckers.
Check all the ground connections to make sure they are tight.I have been having trouble with my 2018 JLUR. The first indication was the center stack below the radio wouldn't come on for up to a minute after starting the vehicle so I couldn't adjust volume or HVAC. Then Traction Control light, and some other warning lights would come on and off intermittently. It wouldn't start one morning 2 weeks ago. I replaced the AUX battery and it worked. Center stack starts as soon as the vehicle is running, no other warning issues. Then I started having voltage problems. Replaced the MAIN battery - O'Reilly said it the old one was too dead to test. Still having issues, I had both batteries tested at O'Reilly's. Both are good. Disconnected the IBS, started vehicle and waited for Stop/Start warning light, shut Jeep down, reconnected IBS. Jeep runs for a day at 14.4V. Next day, it dropped to 13.8V. When I coast, it goes back to 14.4. It seems speed sensitive and not RPM driven as I put in neutral and is still 14.4 until speed drops below 10MPH. I replaced the IBS with a new one purchased at a Jeep dealer for $107. Acts the same. I'm going out now to remove all connections on the positive post on the MAIN battery to make sure they are tight. I read this could cause this issue. I don't understand why this could be sensitive to speed and not RPMs. I welcome any thoughts (short of trading for a Bronco or Caravan).
