Control arms
Islaverde
Good evening just looking for a little feedback and some suggestions, getting ready to put a 3 1/2 inch JKSJ control lift on my 2021 Willis gladiator sport, I have the geometry drop down brackets for the front factory control arms, but my question is Can I install two brand new upper and lower control arms from JKS with the geometry bracket together, lower sets are fixed and uppers are adjustables.Would love some feedback or maybe somebody already has done that installation on their gladiator. Looking forward to any suggestions and would be greatly appreciated, thanks
Yes, you can install the new control arms but you'll want to make sure they are set the same lengths as what you have now/stock. Or, at least so long as you're not needing any additional caster adjustment anyway.
Thank you I appreciate that, maybe I’ll try the brackets with the factory arms, this Gladiator will never see the trails, it will be my daily driver I just want it to look sharp and ride well
The brackets are designed to correct/restore your suspension geometry back to stock with the amount of lift you'll have. If you're never going to see trails, I personally would stick with the factory arms for sure. The bonded rubber bushings they come with will never squeak or need maintenance and for the life of your Jeep. They will also do a better job of absorbing road noise.
