Slight Wobble at 55mph
With my 2015 Jeep JKUR. It has 4in lift on 37in KO2s. Ive been doing a lot of work on it fixing the squeaks and shakes etc. Now its riding awesome but at 55mpg I get a wobble in the steering wheel. Not a death wobble though. It goes away at about 65 or below 54. I know its not a real big deal but I would like to narrow down the cause before it gets to be a bigger problem. All bushings and tie rod ends are new except for the front axle bushings that are annoying to replace and the sway bar end link bushings in the front. New Ball Joints. New tires and wheels. New brakes. New Track Bars front and back. Aftermarket front driveshaft, rear one is stock.
I know its not going to drive like a car but this is definitely different compared to other similar jeeps I've been in.
What should I check first?
See that's exactly what I thought but they swear its been balanced. I may need to take it to another shop to check or get a Road force balance. No idea what they cost or where to get one in Myrtle Beach though, the offroad places here won't do them ugh.
I've pulled out of Discount Tire after a balance and lost both styles of weight; if they're not pulling them off, stripping the weights and rebalancing, find another shop.
I rotated the front right one to the back first and it acted like it got a little better but it was hard to tell, I could be mistaken. However, when I did the front left to the rear, it went away entirely. So, I assume it's that front left one that is now on the back that's the issue.
If the shimmy is gone I wouldn’t do anything. Could be some cupping or something with your front tires and it’ll even out now that they are on the back.
While I have your attention, what do you recommend I run my tire pressure at on the highway? I have it at 28PSI based on AI's research lol. Does that sound right for 37in KO2s?
