Ddays
I used duckduckgo instead because I value my privacy.
Bless your heart Bob
The search query is private by default. It blocks advertising trackers, but the search results are done in your own "bubble" by default so they obviously figure out who you are. It is easy to find that you are in a bubble by searching for yourself. If you seem to be as famous as Mick Jagger then you are in the bubble.Duckduckgo doesn’t keep anything private
Are you forgetting that unless you’re running through a VPN your ISP knows everything?The search query is private by default. It blocks advertising trackers, but the search results are done in your own "bubble" by default so they obviously figure out who you are. It is easy to find that you are in a bubble by searching for yourself. If you seem to be as famous as Mick Jagger then you are in the bubble.
Do you have a search engine which is truly anonymous and private?
DDG caved in to the $$$$ of data collection, they collect everything.The search query is private by default. It blocks advertising trackers, but the search results are done in your own "bubble" by default so they obviously figure out who you are. It is easy to find that you are in a bubble by searching for yourself. If you seem to be as famous as Mick Jagger then you are in the bubble.
HTTPS blocks seeing the content, but does reveal the IP addresses used to the crummy ISP. "DNS" lookups are now usually done using a secure connection to a caching proxy (which is not your ISP) and only use real DNS when that fails.Are you forgetting that unless you’re running through a VPN your ISP knows everything?
there's a large group of them in Orem where Charlie Kirk was assassinated. FBI saying no connection to the group and the shooter...Didn't know there was a Socialist Rifle Association. Sounds like a fun group.
Members of Leninist, Transgender ‘Socialist Rifle Association’ Linked To String Of Violent Attacks
A 10,000 member-strong group called the Socialist Rifle Association has been conducting weapons training for transgender and Marxist-Leninist extremists, and its members have been linked to at least four major crimes, including the firebombing of Tesla dealerships, a Daily Wire investigation...www.dailywire.com
Was this in the news?there's a large group of them in Orem where Charlie Kirk was assassinated. FBI saying no connection to the group and the shooter...
The group that was "protecting" the pedophile queer reading time in Texas a while back was this group; they were in full gear and had snipers on rooftops.
Brute probably knew about it.Was this in the news?
“On July 4, a group of militants allegedly swarmed law enforcement at an ICE facility in Alvarado, Texas and “opened fire at the unarmed DHS correctional officers.” One of them, Benjamin Hanil Song, is charged with shooting a police officer in the neck.”
it was, they are violent and justify it in the name of protecting the pronouns and democracy.Was this in the news?
