WJCO
Meme King
Don't waste money on that stuff.Next on the list is a truss, RCVs, and BJ deletes up front.
Fair enough. Not doubting you, just for my own education, why are they a waste of money? I can understand the RCVs are probably overkill, and the BJ deletes are mostly because I’m lazy and would rather replace a spherical bearing every now and again vs pressing out/in ball joints. I was legitimately under the impression that the truss does help though, but I’m always open to a new perspective on stuff like this.Don't waste money on that stuff.
The JL Rubicon axel assembly is really strong. The other stuff makes your Jeep more difficult to repair on the trail since the parts are not compatible with stock parts and so it is more difficult to find parts.Fair enough. Not doubting you, just for my own education, why are they a waste of money? I can understand the RCVs are probably overkill, and the BJ deletes are mostly because I’m lazy and would rather replace a spherical bearing every now and again vs pressing out/in ball joints. I was legitimately under the impression that the truss does help though, but I’m always open to a new perspective on stuff like this.
That makes sense as far as the ball joint deletes go, but i haven’t seen any instances where one has failed (yet).The JL Rubicon axel assembly is really strong. The other stuff makes your Jeep more difficult to repair on the trail since the parts are not compatible with stock parts and so it is more difficult to find parts.
You read too much bad information on the internet.That makes sense as far as the ball joint deletes go, but i haven’t seen any instances where one has failed (yet).
Maybe I just don’t know what I dont know, but I don’t think a truss eliminates any factory parts that might need repaired on the trail? As far as I was aware it just added structural rigidity particularly around the FAD to *help* (not prevent) keep the housing from cracking breaking.
And with RCVs, per the install videos I’ve watched, they seem to be a plug and play part, and if I broke one, I can just swap in my stock shaft to get me back home.
But again, I’m absolutely open to being educated on the contrary.
I just think I’m in a place where the stock components are under just enough stress with my setup that some help might be warranted, but also my setup isn’t “big” enough to warrant a $18,000+ one ton setup. So if spending $3000 will give me the peace of mind on the tires and torque that I have, that seems like a reasonable option.
 www.wayalife.com
					www.wayalife.com
				Some people here have had RCVs and did not like the noise that they made, or how sometimes grease would slop out from the CV boot over everything around it. There are some technical advantages to RCVs, but also some negatives.That makes sense as far as the ball joint deletes go, but i haven’t seen any instances where one has failed (yet).
