Will 37s fit?
JPinney
we have a Rubicon X, with the factory 1.5” lift and added a 1” spacer in the front (to compensate for the added weight of new bumper and winch)
From your experience, will 37” tires fit?
Thank you!
Depends on what you consider “fit”. If you’re wanting to run them on factory wheels, no. If you’ll be running wheel spacers or aftermarket wheels with less back spacing, on pavement only.
I think he was saying with different wheels with better back spacing or wheel spacers you'll be fine on the pavement. As far as running offroad maybe on a smooth dirt road. 35's would be a better choice w/o adding a lift.
Yup, this ^^^
Fender clearance isn't really the issue with 37. If needed, you can always trim your fenders. It's clearing things like the rear sway bar links and frame rails/control arms at a full turn.
