EVO Enforcer 2.5" lift questions on JL
epriev
So I have received all the boxes for the stage 4 overland enforcer kit. I was hyped to install it this weekend after watch the rancho lift install video. But then I read through the EVO instructions and got cold feet and I stalled the front bumper and winch instead. And needing a 24mm wrench.
The front follows pretty well with Eddie's video, other than the additional overland bracket steps.
For the rear the instructions show installing a sway bar drop bracket to the frame. The kit has no such part, nor is it listed in the parts list. I can't find one on the EVO website. How necessary is dropping the swaybar?
With only a 2.5" lift, would it be necessary to reroute the parking brake lines, or would they be fine as is. Do you even need disconnect the parking brakes for the 2.5" lift if you are not rerouting the lines?
I also didn't get the rear track bars. The stock should be fine? Does it need or can it be adjusted for proper alignment.
Since the stock rear sway bar links are relocated to the front, could you do the rear 1st? It seems simpler than the front other than hoping you get lucky blindly treading the flag nut on the passenger control arm.
Also, it seems as though it could be driven with just the rear installed, and do the front on another day.
Control arm jam nuts. It says to torque them to 250 or 300 lb.ft. after alignment. Really?
And the final setup instruction say to use a driver's side coil seat on the passenger side if a passenger side ARC is present? What does this mean? Is this the front or rear or both? I didn't see this in any of Eddie's videos.
Thanks in advance.
Thanks in advance.
View attachment 426793View attachment 426794View attachment 426795
Hey can’t believe no one’s answered this yet but I’d suggest calling EVO tomorrow.
Upvote 0
A crescent wrench will work in place of a 24mm
It's not critical to have. If you plan on doing a lot of big flexing on the trail, it will help to prevent over extending your links and potentially have them invert. That's all.
Necessary? No. Again, if you plan on doing a lot of big flexing on the trail, it is a good idea to do as the cables will limit the amount of droop you have.
Safe to assume you got a rear track bar relocation bracket? If so, it's all you really need.
Yes, you can totally do the rear first but even if not, the links are no big deal and can be installed at any time.
You could but you'd be sitting ass high by quite a bit.
Does it really say that?? 150 is all you really need and please save your money and do your own alignment. I have write-ups for that too.
In some instances, you may see some spring bowing after installing your lift. IF you do, you can rotate your upper spring isolator to help compensate for it.
Upvote 0
A crescent wrench will work in place of a 24mm.
I have a Harbor Frieght 5 minutes from me and they had a set with it for $20.
It is not included in the 2.5 inch kit. Should I order a rear track bar?
And one more question. This parts list shows different part number for left & right springs. They were not labeled L & R and came in the same box. How do you tell L from R?
Upvote 0
Honestly, it really isn't necessary. Without it, your axle will be a little off center at ride height but then, it's always off center depending on how much weight you have or don't have in your Jeep. It won't affect performance anyway. That said, a relocation bracket will correct this shift and correct geometry and it's cheaper than a new adjustable track bar.
Assuming they are still making this kit with different part numbers, the passenger side coils are taller.
Upvote 0
Thanks. The wrangler suspension is very different than what I had on the solid axle swapped xterra.
Realistically, how long did it take you to install that rancho kit? Your video was about 1.5hrs. Just looking to plan out when I can tackle it.
Upvote 0
Me personally, I can do the whole lift in about 4 hours. However, I think for most people, it would take at least 8. I would plan for a long day or a weekend.
Upvote 0
So I got the front don't minus the sway bar links. The videos were very helpful. Took me about 9 hours just for the front.
It was getting late, so I left the stock track bar on. The steering looked pretty centered. I'll try that another day.
I attempted the overland brackets, but trying to drivers side, they would not line up. So after close to 2 hours, I gave up.
I'll try the rear tomorrow after work.
It's nice having a daily driver so the jeep can sit with parts off.
Upvote 0
One more question.
On the front brake bracket attached to the LCA, instead of zip tieing it the LCA, would drilling out the mount to attach it to the shock be a good idea, or just cut off the bracket? It doesn't look like it would snag anything if left dangling.
Thank all for help and laughs.
Upvote 0
One more question.
We just cut off the oem bracket from the brake line. It will clear everything fine.
Upvote 0
