Random (non-Jeep) Shit You’re Working On....
Please don't tell me that I am wrong again, but this looks like excellent work to me!
Is the lighter color of the doors due to being fresher wood, or is the wood on the walls in some way different?
sigh, thank you Bob
Yeah, the wood is from the same batch - it oxidizes over time and will eventually turn gray with exposure to the sun. The difference is roughly two weeks between the wood on the shed and the doors
Had some noisy water lines at 4am when the sprinklers would kick on. Swapped out the cheap clips for some noise isolation ones. We will see how it works. Half of the of the old clips were broken anyways… should’ve taken a before picture.View attachment 426586
Original clip:
Noise isolation clip:View attachment 426588
Nice! There must still be some valve or junction which is producing the turbulence and thus the noise. It would be good to identify it. Perhaps replacing that part would remove the source of the noise.
Original clip:
When the solenoid valves feeding the sprinkler heads open & close they cause water hammer. If you install a soft seated check valve before the solenoid valve it'll help absorb the hammer.
Thank you for that tip! I noticed the noisy check valve. I didn’t know I had an option to change that out.
Finally fixed this POS. Crank no start after dying on the road while driving. Was getting fuel but no spark. Checked and/or replaced everything around the sun including cam and crank sensors, spark plugs, coil packs, fuses, main relay, immobilizer… probably something else I forgot.
Anyway also found that when hand spinning the crank and looking through the oil cap, the camshaft wasn’t spinning with it. Okay, timing belt mostly likely snapped or skipping time. Popped the cover and found that’s the culprit. Wasn’t thinking of it at first because cranking sounded so normal.
Water pump is also internal so had to be replaced - also did pulleys and serpentine belts (has 2, power steering + AC and alternator + water pump) and valve cover gasket obviously. All buttoned up and honestly as good as new with all these new parts. Took a few months to accumulate the time to get this done but happy to have it back up and running well to give the Jeep a breather once again.
All this means is more Jeep parts sooner! 😎
Anyway also found that when hand spinning the crank, the camshaft wasn’t spinning with it. Okay, timing belt mostly likely snapped or skipping time. Popped the cover and found that’s the culprit. Wasn’t thinking of it at first because cranking sounded so normal.
Water pump is also internal so had to replaced - also did pulleys and serpentine belts (has 2, steering + AC and alternator + water pump) and valve cover gasket obviously. All buttoned up and honestly as good as new with all these new parts. Took a few moths to accumulate the time to get this done but happy to have it back to give the Jeep a breather once again.
Nice job man, that’s quite the undertaking! You still planning to sell it?
Water pump is also internal so had to replaced - also did pulleys and serpentine belts (has 2, power steering + AC and alternator + water pump) and valve cover gasket obviously. All buttoned up and honestly as good as new with all these new parts. Took a few moths to accumulate the time to get this done but happy to have it back up and running well to give the Jeep a breather once again.
Do the SBC swap and light her up.......
Thanks! Wasn't fun but it's so rewarding to get shit done and hear it turn over for the first time in months.
On the fence. Of course, the whole time working on it and seeing it sit I was like "F this car." and "Why did I buy this POS?" but after driving it again I remembered how much fun it is to drive and how I get almost 30mpg. Plus track days with my friends who have these cars as well were fun too. We'll see.
Edit: In the car's defense, I got ahold of the previous owner and found it was the original timing belt. I'll take it for 150k miles.
It’s the greatest feeling getting a car fixed! I would say keep it and enjoy it for daily driving, saving gas when it’s $8 a gallon 🤦‍♂️ and more parts for the jeep! Speaking of which, no luck on selling your Jeep?
Nobody wants it. Tons of views some phone calls, have lowered the price a ton, even had it appraised at dealers including my own. Can’t justify the difference if I do sell it for what they’ll give me and buy another but yeah, literally 0 offers with thousands of clicks on the apps I have it listed.
Bummed but I have kinda already accepted that I’ll keep and continue building it.
It you did sell it, in a few years you would be feeling remorse that you did so.
Bob
Sorry man, that’s a bummer!
Installed Flair Smart Vents in the bedrooms since the balance of temperature is way off in my house. Now I can control it! View attachment 421378View attachment 421379
Very cool tech! Keep us informed on how it works. I’m in the same boat.
Just thought I’d follow up. I have been very impressed with this smart vent system. Took a little while to get it rolling but I love having it. I want to order the vents for the rest of the house now and not just the bedrooms.
