What is this leak? How do I fix it?
So, tonight, I went exploring in my jeep (near my house) and found a trail I had never seen before. It had been washed out pretty badly (in multiple places) and I tried driving down it. At one point I got my jeep at a pretty steep angle trying to get through the washout and also laid my jeep down on its belly (nearly high centering). I also was a bit mushy with the clutch and I think I burnt it a little (which I usually know better, but I am a little out of practice).
Afterwards, we noticed some oil on the ground just past where this took place and looked under the vehicle to see a lot of dripping oil on the transmission.
Can you all tell me what happened and how do I fix it?
BTW, this is a 2019 4 door with a manual transmission, if that is helpful.
How many miles? looks like the cursed oil filter housing/cooler.
Take a long zip tie or something similar and slide it down along the side of the oil filter housing like a dip stick.
If it's covered in oil when you remove it, it's the oil filter housing/cooler leaking.
The Dorman oil filter housing/cooler is what I would replace it with.
There are cheaper aluminum units on Amazon, but I wouldn't trust them.
It's not a difficult job but time consuming, the JL has some extra stuff in the way that makes it necessary to drain the coolant.
Yup and yup. What he said ^
