NorthCountry
Thank you and safe travels
If you're talking about the Carrier Bearing support, it's 46 lb-ft.Nice sheets. I am looking for the rear axle shaft mount plate nut torque setting. Does anyone know them? Thanks for the Help
I think he is talking about the axle shaft retainer that has the 4 18mm nuts holding the shaft in the axle tube. If that’s the case it should be 60ft/lbsIf you're talking about the Carrier Bearing support, it's 46 lb-ft.
