kevman65
That sucks.Fixed a gator someone wrecked yesterday.
Did a gas golf cart that DIDN'T make a ditch jump once.
I imagine your repair was as much fun as mine was.
Those things are so cheaply made…they are always breaking.Fixed a gator someone wrecked yesterday.
Fun is a good word to describe itThat sucks.
Especially when you park them at the top of a hill and don’t set the breakThose things are so cheaply made…they are always breaking.
Switching out my commie gas nozzles to the good ones. Doing the Lord's work.
View attachment 413495View attachment 413496
Best mod ever!!Switching out my commie gas nozzles to the good ones. Doing the Lord's work.
A new fence?Turf is done (mostly) in the front
Got one big seam done in the back, 2 more solid days back there should get me mostly done.
Then I just need to drop a few grand in pavers to fill in the dirt spots and another thousand worth of retaining wall stackers then… the wife will find something else
That’s vintageA new fence?
I need thatSwitching out my commie gas nozzles to the good ones. Doing the Lord's work.
The gaskets all rotted on the replacements I boughtSwitching out my commie gas nozzles to the good ones. Doing the Lord's work.
Bummer. Did you only find the leak because it was doing damage to the ceiling?Building contractor left two pipes resting on each other. Dip shit. Thank God it was a drip and not a spray and ceiling will dry out fine.
View attachment 414257View attachment 414258
Shark Bites winning as usual.
Luckily there was an access grate there from a prior shower drain repair. I kept hearing a clicking noise this morning. It was water dripping from the grate onto the floor. Pulled the grate and ran an inspection camera and found the pipe about a foot away. Had to cut a new hole so now there will be a giant new access grate. Oh well.Bummer. Did you only find the leak because it was doing damage to the ceiling?
Fuckers. Probably a redneck too.Damn home builders
Well that sucks but good thing you caught it before it got any worse.Luckily there was an access grate there from a prior shower drain repair. I kept hearing a clicking noise this morning. It was water dripping from the grate onto the floor. Pulled the grate and ran an inspection camera and found the pipe about a foot away. Had to cut a new hole so now there will be a giant new access grate. Oh well.
 Probably my biggest fear when we walk away from a job.  Cool you got it fixed.
