Disciple Off Road
Upgrading your front axle shafts to chromoly's has always been a go-to upgrade for most when running larger tires for added strength and, to ditch the factory half circle clips on the u-joints. Options for this upgrade have been very limited for the JL and JT to Spicer or RCV's and, not everyone wants to spend $1,500 on a set of axle shafts.
Revolution Gear and Axle has finally release their front 4340 Nickel Chromoly axle kits in three variations for your specific application and with Spicer 1410X u-joints. These kits are only for the DANA 44/M210 Wide-Track front axle with the 32 spline locker. Kits are available now to order.
For a limited time, use REV10 at checkout at Disciple Off Road and save 10% on some new Revolution axle kits!
Revolution Gear Discovery Series 2018+ Wrangler JL and JT Chromoly Front Axle Kit (reuses factory passenger inner shaft)
Revolution Gear Discovery Series 2018+ Wrangler JL and JT Chromoly Front Axle Kit with FAD
Revolution Gear Discovery Series 2018+ Wrangler JL and JT 1-Piece Chromoly Front Axle Kit
Warranty: Revolution Gear & Axle Discovery Series Axles are backed by a 10 Year Warranty covering manufacturing defects and axle breakage, bent axles and twisted splines. This warranty is non-transferable. U-Joints are only covered under warranty against manufacturing defects for 1 Year (Front Axle Kits with Revolution Gear HD Chromoly U-Joints carry a limited 10 Year Warranty)
