Ah well the retailer should be doing the leg work for you then. Hope they get it taken care of for you.I checked everything and changed the fuse in case even if it was looking good and there is power at the outlet! I bought it from a retailer in canada so Quadratec told me to contact them! I did and they told me they never seen that![]()
Apply power and ground directly to the light using jumper wires from the battery. If it doesn't work, it's a bad light. If it does work, sounds like you have a bad ground connection (since you said power is good at the light).I checked everything and changed the fuse in case even if it was looking good and there is power at the outlet! I bought it from a retailer in canada so Quadratec told me to contact them! I did and they told me they never seen that![]()
