I noted that my front locker wasn't working after getting it back from re-gearing. I bought the Z Automotive sensor bypass jumper just before a trail trip a couple weeks ago. Nothing. We ran Backway to Crown King and really didn't need lockers.
Yesterday, I dug into it. The locker hall effect sensor was full of oil. So, theoretically, if it was just the sensor, the Z Automotive sensor bypass jumper should have bypassed the sensor and provided power directly to the 2 wires (ground and power) that go to the magnet in the actuator. I chased the wiring with a continuity light and found I was getting power (with the Z Automotive jumper) all the way to the connector where the actuator plugs in, inside the diff housing. So, it's something with the actuator assembly from either the connector, wiring, or the coil that is the problem I cleaned the hell out of the connector and eyeballed it closely. It looks good and the wires to the connector and the actuator look great, no pinches, kinks or any other anomolies.
