JediNighT
| I've caught the Overlanding Bug... That being said, I'm changing the suspension setup, adding camping and off-grid systems. There’s lots of work to do and pics to take. Stay Tuned… |
| BUILD GOAL: Build a rig with the capability to overland CONUS and OCONUS, while using accessible replacement parts, ability to stay off-grid for up to 7 days, light rock crawling and water fording when required, while incorporating a smooth ride for long hauls. |
| Suspension: |
| EVO Coils Springs Front and Rear 4.5in |
| Fox Performance Shocks 2.0 IFP Front - 4.5in (will upgrade to 3.0 Reservoirs) |
| Fox Performance Shocks 2.0 IFP Rear - 4.5in (will upgrade to 3.0 Reservoirs) |
| Front Bump Stops |
| Front & Rear Bump Stop Spacers |
| Front & Rear Brake Line Extension Brackets |
| RockJock Anti-rock Front Sway Bar Kit |
| RockJock Anti-rock Rear Sway Bar Kit |
| EVO Front Adjustable Upper Control Arms |
| EVO Front Adjustable Lower Control Arms |
| TeraFlex Alpine Rear Adjustable Upper Control Arms (to be replaced by EVO) |
| TeraFlex Alpine Rear Adjustable Lower Control Arms (to be replaced by EVO) |
| The Skyjacker 3.5 - 6 Inch LeDuc Series Coil Over Lift Kit w/6inch lift, rode too harsh from too much pre-load and ride height |
| Steering: OEM Gear Box steering w/Synergy + Fox replaced by PSC/YETI |
| PSC Big Bore Hydro Assist Steering System for UD60 |
| Yeti Steer Smarts XD Adjustable Draglink for UD60 |
| Yeti Steer Smarts XD Adjustable Pro-Series Front Track Bar |
| Yeti Steer Smarts XD Adjustable Pro-Series Tie-Rod |
| Drivetrain: |
| Dana Spicer Ultimate Dana 60 Front and Rear Crate Axles with 4.88 Gears & Eaton E-Lockers |
| Dana Spicer UD60 Front and Rear Drive Shafts |
| Body Armor and Roll Cage Reinforcement: |
| Addictive Desert Design front bumper w/stinger |
| Wolfstorm Rear bumper w/winch |
| Rock Hard Complete Sport Cage System |
| RC Skid plate system |
| Raptor Lined Tailgate, Hood, and interior cab shell |
| Storage: |
| 2 - RotoPax 2 Gallon Water Cells |
| 4 - 8 Gallon Fuel Cells (cutting back to 2 to save space, after installation of Long Range Aux Fuel tank) |
| 4 - RotoPax storage Containers |
| Vector Off-road Cargo Basket |
| TrailRAX PaxRack Mount x 2 |
| Echotechne Hood Rack |
| Molle Storage systems for rear cargo windows and front & rear roof |
| Water Fording: |
| Hauk Off-Road Snorkel w/axle breather kit (Front & Rear Axle and Transfer Case) |
| Wheels & Tires: |
| Cooper 37x12.50 R20 (moving to 38/13.50 R17) |
| American Truxx AT1902 KUTZ Black/Machined 20x9 (moving to 17x9 bead locks) |
| Vehicle Power: |
| 2.1 Battery system |
| Genesis Off-road Dual Battery Kit with Dual Optima AGM Starting batteries + 12v Aux Battery wired in parallel with Genesis Dual Battery Kit for Rear Winch |
| Lighting: |
| Rigid Lighting System (front, rear and sides) |
| 50in light bar single row |
| 50in light bar double row |
| 40in light bar |
| 30in light bar |
| 20in light bar |
| 20 3x3 cube lights |
| Oracle Cargo Light Module |
| COMMS/Infotainment: |
| Kicker Speakers and Sub - Full Cabin |
| Midland GMRS |
| Uniden Bearcat CB |
| weBoost Drive Reach OTR range cell extender |
| Full cab sound deadening padding of floors, hard top and doors coated with Raptor Liner |
| Recovery: |
| Smittybilt XRC GEN3 12K Winch - Steel Cable - Front |
| Smittybilt X2O 10K Winch - Synthetic Rope - Rear |
| 52K Kinetic Recovery Rope 32’ |
| Tree Saver 30K 8’ tree saver winch Strap |
| Tow strap 30K 40’ |
| Rhino 41K D-Ring Shackle x 4 |
| Smittybilt 17K capacity Snatch Block |
| Smittybilt 36K capacity Snatch Block |
| Overlanding Camp Gear: |
| iKamper Skycamp 2.0 |
| iKamper Skycamp Annex |
| Rhino Rack Pioneer platform |
| Goose Gear Deck Platform w/60% rear seat delete |
| ICECO VL75 ProD Dual Zone Fridge w/insulated cover |
| Thetford Porta-Potti w/ pop-up privacy room |
| Rhino Roof Mount Side Shower Room |
| Custom pressurized water system w/ Front Runner 10.6 Gal Tank |
| Tankless Portable Gas Water heater |
| Goose Gear Sleep Deck |
| Off Grid Power: |
| Renogy 100W Flex RTT Solar Panels x 2 |
| Renogy 12V 50A DC to DC On-Board MPPT Solar Charge Controller/Battery Charger |
| Renogy 1000w Pure Sine Wave Inverter Charger 12V DC to 120V AC Surge 2000w Off-Grid Solar Inverter |
| 12V 100Ah Smart Lithium Iron Phosphate Smart Battery (may add another depending on power needs) |
| Custom NOCO Shore Power Connection |
| Additions to completed Build/Coming Soon: |
| Long Range America Aux Fuel Tank |
| ARB 12v Twin Air Compressor System |
| Speedir Night Owl Thermal Driving Night Vision System |
| HD Split Screen Rearview Mirror w/ Front and Rear facing camera's |
| 12.1 Tesla Touch Screen Multimedia Head Unit |
| Method MR106 Bead lock 17x9 Wheels or KMC Machete (on the fence) |
| Artec Industries Front Dana 60 Truss |
| Artec Industries Rear Dana 60 Truss |
| OBE Parts List: |
| Steering: |
| OEM Jeep JLUS Steering System (for JL) |
| Synergy Front Track Bar & Sector Shaft Brace (for JK) |
| Synergy Heavy Duty Tie ROD (for JK) |
| Synergy Heavy Duty Drag Link (for JK) |
| RockJock Heavy Duty Steering System (for JL) |
| Heavy Duty Tie ROD |
| Heavy Duty Drag Link |
| High-Mount Steering Stabilizer Relocation Bracket |
| FOX Performance Series 2.0 TS Steering Stabilizer |
| Teraflex Falcon Nexus EF 2.2 Fast Adjust Steering Stabilizer |
| Heavy Duty Stabilizer Shock Mount |
| Suspension: (for JL) |
| SkyJacker Front & Rear Coil-Over Shocks |
| SkyJacker Front & Rear Coil-Over Shock mounts |
| Skyjacker Front & Rear Adjustable Lower Control Arms |
| Skyjacker Front Adjustable Track Bar |
| Skyjacker Rear Track Bar Bracket |
| EVO Heavy-Duty Adjustable Front Track Bar |
| Front & Rear Extended Sway Bar End Links |
| TeraFlex Front Adjustable Upper Control Arms |
| TeraFlex Front Adjustable Lower Control Arms |
| TeraFlex Heavy-Duty Adjustable Rear Track Bar |
| Drivetrain: (for JL) |
| G2 Rear Drive Shaft |
| G2 Front Drive Shaft (broken seal) |
| Dana M200 Rear Axle |
| Brakes: |
| Grimm Off Road Extended Brake Line Kit |
| Wheels/Tires: |
| Black Rhino Shrapnel Wheels 20x9 x 5 |
| Nitto Trail Grapplers 35x12.50 R20 x 5 with 15K miles x/32 tread wear |
| Mopar Stock 17X7.5 Tech Silver Aluminum Wheels x 5 new take-offs |
| Michelin 245/75R17 All Season Tires x 5 (stored indoors control temperate setting) |
| Storage: |
| EAG Roof Rack (for JK) |
