mgmavant
So I'm having some issues after installing a front track bar relocation bracket today. Last week I installed the 4" EVO Enforcer lift kit, and I installed everything from that kit without any issues. The caster was set at ~4 degrees after the install, and the rear axel was centered with the Evo rear roll center correction bracket that came with the lift. I had a JKS adjustable rear track bar, but I was able to set that to the proper length without any issues. After the install, the Jeep drove great - no issues at all (after recentering the steering wheel). I ran out of time to do everything I wanted to do last weekend, so I still had to install the extended brake lines, a new drag link, the front track bar relocation bracket and ball joints.
So today I figured I would work on the brakes and the front track bar relocation bracket. I got the brakes swapped out without any issues, so I did the track bar bracket while I had the front wheel off. The bracket installed just fine without any issues, but when I did the test drive, the steering feels really flighty now. The Jeep also will feel like it's being torque-steered when I step on the gas pretty aggressively (it's a 2008, so I've got the 3.8 and it's a manual - 35" tires with 4.10 gears). It almost feels like I don't have enough caster, but why would that have changed when all I did was the track bar bracket?
I checked the caster and it looks like it's right around 4 degrees, I've tripled checked all the bolts to make sure they are all tight and to spec, and everything looks really good. The only thing that seems a little odd is the passenger side jonny joint is not aligned very well. I straightened it out, and retorqued everything, but the Jeep still drives the same and the joint went back to the way it was before. I think it did this before I did the front track bar bracket, but can't be 100% sure.
Because I'm still waiting for the 13/16" bit to come in the mail (no store around here seemed to have it so I ordered one on line) I didn't install the new drag link (it's a flip kit). So my question is did I mess up and install the track bar bracket too soon? The only thing that changed was raising the track bar and the sway bar end links - I had raised the steering stabilizer before with a separate bracket, so this new bracket only rose that a little bit.
Any help would be greatly appreciated.
