Rock40
Clutch master and pedal retrofit. 316 stainless to make a clevis in the correct width for the pedal. I looked, not available commercially in the size I needed
Pedal alignment. All three are finally hooked up here
UHMW spacer for the master. This helps space the master out far enough from the firewall to ensure it is getting the full "throw" from the pedal
Added a threaded rubber pad to the bottom of the pedal. That way it won't slam against the floor every time the clutch pedal is depressed
