It's Time to SUPERSIZE Moby - MoTech 6.2L LS Jeep Motor Swap
Eddie, how much more would you say (ballpark) this setup (motor/trans) weighs over the OEM 3.8 or 3.6 with tranny?
It's Time to SUPERSIZE Moby!
The motor is just slightly heavier than a 3.8L - from what I have seen, under 10 lbs. The 6L80 tranny is heavier but not enough to make a huge difference.
Oh wow. Thats awesome. So it really is a "no drawback" swap. The 3.8 is an iron block right?
...... The 6L80 tranny is heavier but not enough to make a huge difference.
it's also keeping that little bit of extra weight right in the middle of the wheel base and along the centerline. That's always a plus if you are adding weight and it's due to the drivetrain.
Exactly, it's a win win in my book
LOL!! Yeah, Moby lost his warranty a long long time ago and only recently found that he had been flagged as well.
DAY 3 - GETTING THE LS READY
Here is a summary of what we accomplished today...
-Tack welded in the new MoTech Frame Mounts
-Installed the new Harmonic balancer
-Installed the MoTech brackets for the JK alternator, JK PS pump and JK A/C compressor
-Installed the new exhaust manifolds
-Installed the MoTech transmission mount
-Installed the Atlas transfer case adapter on the transmission
-Removed the old GM wiring harness
-Installed the new MoTech LS JK wiring harness
-Test fit the LS 6.2L motor in Moby
-Ordered a few more parts that we were missing
A few more pics...
The hole that needs to be filled :)
The new MoTech Frame Mounts tack welded in
Installing the new Harmonic balancer
The MoTech JK alternator bracket installed
The MoTech JK PS pump bracket installed
The MoTech JK A/C compressor bracket installed
New exhaust manifolds installed
The old GM wiring harness removed
Installing the new MoTech JK LS harness
Installed the MoTech transmission bracket
Installing the Atlas transmission adapter
Test fitting the LS motor!
Tessa wondering if we will ever finish working on Moby so we will play ball with her :)
