So 500 mile break in gear oil change in 2022?
Looking good :thumb:
Just catching up on your thread.
Congratulations on the new axle[emoji106][emoji106]
Confidence to explore.
Winter project parts almost all here
I’ll get started after this trip unless everyone talks about getting together again.
Put the Artec lca skids on today, not super happy with how they fit
I’ll rip out the factory axle next and get the gears done in the new axle
I see how on the sly you did that ...nice! :thumb:
Congrats on the prorock!!! Can’t believe I missed that!!
That's awesome Mark![emoji106][emoji106]View attachment 354832
Gets dropped off Tuesday, picked up Thursday or Friday
I had the JKS brackets on my stock axle that moves the bottom of the shock out and turns it too. It measures 2” from the “C” to the bracket.
The PR44 shock mount must already be 1/2” more outboard, meaning if I use the brackets the shock will be more outboard
But with slabs at 3.5” backspacing these should still work I think. Does anyone see a problem?
The only problem I see is that you are going to ha e get them scratched and dirty. You ok with that?
Seriously though I don’t see it being a problem but can’t you measure off the mounting surface to confirm or aren’t they mounted up yet?
Just looked at my ProRock and I don’t think moving it out farther will hurt anything.
Sent from Lookout Mtn.
Thank you for looking Steve I’ll put them on [emoji106]
Yup, those are never gonna work on Brick. Luckily for you I'll take them off your hands seeing as they're no longer being made.[emoji12]I had the JKS brackets on my stock axle that moves the bottom of the shock out and turns it too. It measures 2” from the “C” to the bracket.
