fiend
Did you look up 12v?
http://www.offroaders.com/technical/12-volt-wiring-tech-gauge-to-amps/
Either way the actual rating for that particular wire is written in the wire and easy to check.
I didn’t look up any particular voltage. The link I provided says it’s just a guide. The link you provided is even better. An additional consideration your link raises is that amperage depends on the length of the wire in the particular application. Your 125 amp suggestion should be fine given the probable length used here.
