Lucky - a 17 JKU build
I juts rebuild my ProSteers over the weekend, because I started getting death wobble. Chris (Arrcherr) and I, found a decent amount of play in the balljoints after closer inspection.
Was it as much of a pain in the dick as everyone is saying? Absolutely not. It was time consuming though for sure. The only thing that would make this job a lot easier is a shop press. Or just take all 4 joints out and take em to a machine shop to get the heims pressed. Beating the heims in with a hammer like a barbarian isn’t ideal lol.
All joints came out with ease without any issues. As far as the seals, I had no issue with the glue sticking, just make sure you prep your surfaces correctly, and clamp them on for a little while. By the time you put everything back on the glue should be set, just be mindful how much grease you are pumping in there, a little goes a long way.
With all that said Jeep drives like new again, and $130 for rebuild kits is well worth it. I have no regrets of dropping the money on ProSteers and having the option to rebuild them down the road.
Nice work Matt and Chris [emoji106]
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Yep pretty much my experience so far with the ProSteers I’ve must of got lucky.
That's great to hear. I've heard so many good things about these ball joints hence why I pulled the trigger so I was surprised to hear the negatives, good to hear your experience. BTW what grease do you use on these. I've been using Lucas heavy duty grease nlgi #2, I'm not really familiar with the different types.
Sent from my SM-G965U using Tapatalk
That’s the grease I use, on everything. The green, heavy duty one.
How many miles on them?
Find this debris after taking the shaft out. Any issues I should be aware of? Some sort of seal? 20200710_123857.jpg20200710_123901.jpg20200710_123913.jpg
That moment when you get everything buttoned up and you didn't position the zerk fitting where you can reach. FML20200710_161853.jpg
