JK07
For Sale: Rubicat 2012 JKUR, 40's & 60's
SALE PENDING!
Hello Wayalife,
I have been the proud owner of Rubicat for a little less than two years and sadly, I think it might be time to move on to another vehicle/project. I really enjoyed getting to meet Eddie & Cindy and I have had a great time with Rubicat. Including an amazing bucket list trip, the 2019 JKX.
I have certainly enjoyed the process of putting my own small touches on this already awesome Jeep. Several maintenance items have been addressed under the hood, including swapping out an oil-burning factory 3.6L. While I would have loved to drop it off at MoTech, my decision was to go with a remanufactured 3.6L from Jasper. I also recently replaced the transmission after that failed. While in there, a bunch of parts were replaced to take advantage of the engine-out opportunity.
Rubicat currently has 115,814 miles on her. I bought her from Eddie & Cindy on June 1, 2018 with 100,407 miles.
I recognize that I am not a very active forum member so I reached out to Eddie for permission to post this listing. Thankfully, he agreed. It would be really cool if another Wayalife member could be the next owner of Rubicat!
I am listing Rubicat for sale at $46,000 (price drop 6/22/20). Serious offers will be considered. Vehicle Title in hand. Rubicat is located in York, PA.
Thanks for looking! PM me for more info if needed.
- Jason
Build List (+ designates additions I made after purchasing Rubicat from Eddie & Cindy)
Rubicat: 2012 Jeep Wrangler Unlimited Rubicon - 115,814 Miles
3.6L V6 24-Valve VVT Engine
5-Speed Automatic W5A580 Transmission
Rubicon 4:1 Transfer Case
Electronic Sway Bar Front, Stock Sway Bar Rear
Color: Dozer
Black Cloth Interior
Media Center 130 CD/MP3 (included)
Full Doors w/Powered Deep Tint Sunscreen Windows
Power Convenience Group
Tow Package
Suspension
EVO MFG Double Throw Down Coil Over Kit - Rear (EVO Lever)
EVO MFG Double Throw Down Coil Over Kit - Front, Custom King Bypass Shocks
EVO MFG High Clearance Long Arm Kit
EVO MFG HD Sway Bar Links - Front
EVO MFG HD Sway Bar Links - Rear
King Racing Shocks Air Bumps - Rear
+JKS MFG Adjustable Front Track Bar
+JKS MFG Adjustable Rear Track Bar
Axles
Dynatrac 72.5” Custom XD60 Front Axle 5.38 gears
Dynatrac 72.5” Custom ProRock 60 Full Float Rear Axle 5.38 gears
Dynatrac 1550 Pro Knuckles
Dynatrac Custom Tie Rod
Dynatrac Installed Brackets for EVO MFG Double Throw Down Suspension
ARB Air Lockers
JE Reel 1350 Drive Shafts Front & Rear
Stainless Steel Air Locker Lines
Wheels & Tires, Brakes, Exhaust
Cooper Discoverer STT Pro M/T Tires 40×13.50 (5) installed for ~20k miles
Trail Ready HD17 Beadlock Wheels 5.5” backspacing (5)
Dynomax Quiet Crawler Exhaust System
+Mopar J8 Master Cylinder/Brake Booster Kit
Stainless Steel Brake Lines
+Magnaflow Exhaust Hoop Delete
Steering
PSC Ram Assist Steering
EVO MFG Custom XD60 PSC Ram Skid
Dynatrac HD Drag Link Sleeve
+PSC Dual Cooler (Steering & Transmission)
Armor / Body
EVO MFG 1/4 Pounder Front Bumper (Stinger removed but still have)
EVO MFG Tire Carrier
EVO MFG Rock Sliders
EVO MFG Rear Quarter Panel Body Armor
EVO MFG Rocker Skins
+EVO MFG JK Rear Fascia (Steel) w/reverse camera
EVO MFG Rear D-Ring Mounts
EVO MFG ProTek Oil Pan Skid Plate
EVO MFG D-Ring Mounts Front
+EVO MFG HiLift Jack Mount
+EVO MFG Gate Plate
+EVO MFG Mini Fender Liners
EVO MFG Vacuum Pump Relocation Bracket
+Poison Spyder Wide Aluminum Crusher Flares F+R, Powder Coated Black
+Synergy MFG Gas Tank Skid
+Mopar Premium Twill Soft Top
+RockHard4x4 C-Pillar Brace Kit Powder Coated Black w/padding & cover
+Rain Gear Trail Cover
+Mopar JL Hood Latches
+Team Tech Offroad Hood Strut Kit
+Vector Offroad UFO’s
Interior
EVO MFG Sport Cage - Complete w/Handles
+ARB Outback Solutions Drawer System
+Switch-Pros SP9100 8 Switch System w/soldered 14ga OFC cables in flex loom
+Bartact Seat Covers (Black)
+Sony XAV-AX200 CarPlay Head Unit
+AudioControl Epicenter Bass Restoration Processor
+Rockford Fosgate Power T1000AX5 5-Channel Amplifier
+Sundown Audio 10" Shallow Mount Subwoofers SD-3 10 D2 (2)
+Mattk11 (JK-Forum) Custom Fiberglass Under Seat Subwoofer Enclosures (2)
+Rockford Fosgate Power Series T1650 Coaxial Speakers (Sound bar)
+Rockford Fosgate Power Series T1675 Coaxial Speakers (Front)
+KnuKonceptz 0 Gauge OFC Amplifier Wiring, 14 Gauge OFC Speaker Cable
+ProClip Dual Phone Dash Mount + RAM Ball
+Midland MXT275 GMRS Radio + 6db Antenna on Driver’s Side Rear Corner Armor
Anytone CB Radio + Firestik II Antenna
+Jeep Unique Handheld Radio Mount
+Spiderweb Sun Shade 4dr
+Innovative JK Designs Rear Seat Recline kit
+Front & Rear Quadratec Floor Mats
Lighting
Truck-Lite LED Headlights
+Warn 10” Light bar (Flood)
Rigid D2 A-Pillar Lights - Spot
+Rigid Chase Light as Third Brake/Reverse
+EverStart AGM Battery Installed 3/2020
+Rigid Ignite Rear Fascia LED Lights
+KC HiLites Cyclone Dome Lights - Clear (2)
EVO MFG LED Tail Lights
EVO MFG Fairlead Light Mount
+EVO MFG A-Pillar Light Mounts
Recovery
+WARN Zeon 10-S Platinum
ARB Single Compressor w/EVO bracket
+Factor 55 ProLink Blue
+EVO MFG Aluminum Hawse Fairlead
+Bartact Warn Zeon Winch Cover (Black)
Engine & Transmission
+Jasper Remanufactured 3.6L Pentastar Engine (12/16/19 @ 114,726 miles)
+Jasper Remanufactured W5A580 Transmission (12/16/19 @ 114,726 miles)
+Ripp Performance Coil-packs
+HikeIt X9 Throttle Controller
+Parts Replaced During My Ownership
O2 Sensors (4)
Catalytic Converters (2)
Mopar Engine Wiring Harness + Sub Harness Bank 1
Mopar Radiator, Hoses & Temp Sensor
Mopar AC Compressor
Mopar Lower Steering Shaft
Mopar Remanufactured Alternator
Mopar Water Pump
Mopar Belt Tensioner
Mopar Heater Hoses
Mopar Oil Line Set
Mopar PCV Valve
Mopar Crank Pulley
Mopar Idler Pulleys
Serpentine Belt
Thermostat & Housing
Mopar 4wd Shifter Cable
EVO MFG HD Rear Sway Bar Links (heims were bad)
Heim Joints Front EVO MFG HD Sway Bar Links
Heim Joints on EVO Lever
Spare Parts Included
Currie Johnny Joint Rebuild Kits (10)
Currie Johnny Joint Rebuild Tool
(2) Spare Tie Rod Ends
Swepco 715 Power Steering Fluid (6qt)
Dominion Offroad EVAP relocation Kit
Crown Rear Stainless Braided Brake Lines
Dana Spicer 1550 U-Joint
Dana Spicer 1350 U-Joint
Mopar Wheel Speed Sensors (2)
Set of 4 Trimmed Factory Fenders
Bestop Trektop NX Soft Top - Diamond Fabric (old/worn)
1 Set of Wagner Rear Brake Pads
Additional pictures can be found on Instagram @Rubicat18
SALE PENDING!
Hello Wayalife,
- Jason
Color: Dozer
Tow Package
Suspension
Axles
ARB Air Lockers
Steering
Armor / Body
+EVO MFG Gate Plate
Interior
Lighting
Recovery
O2 Sensors (4)
Mopar AC Compressor
Mopar Water Pump
Mopar Heater Hoses
Mopar Oil Line Set
Mopar PCV Valve
Mopar Crank Pulley
Mopar Idler Pulleys
Serpentine Belt
