What problems does your Jeep have this week?
I have used a variety of methods including burning out the rubber and then splitting the sleeve so it will press out easy. My conclusion is that if time is money the labor hrs involved are greater that just buying new control arms. Have fun! Yes replacing bushings sucks!
Sent from my iPad using WAYALIFE
The thought had crossed my mind. I’m half way into it at this point, so I’ll see it through to completion. Hopefully these new bushings last a while. I got 8 years out of the Clevites.
Got the dreaded misfire code, did the coils, plugs, and wires. Turns out it was fuel injector was bad... that job was a bit of an a**hole just because you have to reacquaint yourself with an old nemesis, the EGR valve. I took some pictures if you guys want a mouth breather’s guide to swapping fuel injectors.
Original Radiator Cracked
Found a crack on the radiator. Luckily the Jeep never overheated. Any suggestions on the most affordable options for replacement? The cheapest brand I found is Spectra and it has some good and bad reviews just like everyone else out there. Anyone got any experience with Spectra?
Advance auto. Use a coupon code online pick up in store.
I just changed mine for the same reason. Installed the Spectra without issue. Looked just like the leaking oem junk I pulled out.
HAPPYTRAILS
Still tracking down a leak in my rear air locker. I’m going to try and pull the hose off the diff and see if Its clogged or has diff fluid in it.
Picked up new u joints for front axel
When I put on the crossover steering kit discovered that the u joints are bad on both sides. Seams like a good job to tackle during quarantine.
Sent from my SM-G965U using WAYALIFE mobile app
This can't be a good sign.
I came out this morning to oil under the rear of the Jeep. First thought was diff cover, but looking closer, it was too far back.
Why is my muffler oily?
I checked engine oil, way low. Ugh.
I went to the back to get my spare oil I carry, and it is low, and oil is everywhere. Something must have picked a hole.
Now I'm not sure if the puddle was from the jug of oil? I hope so.
On the other hand, it seems I am burning a lot of oil for some reason.
After looking closer at the pics, I'm pretty sure at least most of it came from my spare jug of oil, but....
It’s difficult to image a scenario in which liquid oil like that would be coming from your engine and through your exhaust pipe.
I’m thinking maybe your spare oil cache sprung a leak.
A busted shock could also leak oil back there, but it would be obvious that’s it’s coming from the shock.
Very true, but if it could happen to anyone it would happen to Jerry. [emoji23]
Yeah I can’t imagine that oil would make it all the way back there. Engine would have to be running and most any oil would hit the hot exhaust and smoke and burn long before it made it even halfway back
