What's In The Bed Of Your Gladiator?
What length did you cut the 2x4's?
I'll measure later and let you know but I have some more details about it here: https://jlwrangler.com/showthread.p...-JT-Build-Thread&p=57533&viewfull=1#post57533 and here https://jlwrangler.com/showthread.p...-JT-Build-Thread&p=57665&viewfull=1#post57665 .
Front one over the wheel wells is a 2x4. Rear one is a 2x6. You have to cut the bottom corners or it won't slide all the way down. I left about an 1/8" short on each side and put some random pieces of rubber in to keep it from rattling.
Can you roll up the rear soft window To the top?
Pretty sure the rear window doesn’t roll. You’re seeing his tonneau at the bottom.
I see the tonneau roll, still wondering if the rear window rolls up...
Judging by quadratec's install instructions it looks like it should be the same as a JL rear window.
It does not roll up at all. It only slides out horizontally. The white part is 3 feet long or so and slides in and out of that black channel. No zippers at all.
You can however remove the rear window and two corner caps (you have to remove all 3 together) and leave the roof part of the top on the truck for a nice Joe Dirt look though.
Such a great work truck! That makes short work of that chore.
They won’t let us rent anything in Michigan right now. It’s mind boggling
2015 JKUR AEV JK350
1985 CJ8 Scrambler
