3.5 metal cloak lift, 35in tiresAre you have a lift installed or still stock? If you have a lift installed, which one is it?
Have about .75in dip in the front and .5in in the rear. Been reading other forms, seems the only fix is leaving kit for the passenger side. I did take it to the dealer after installation for correct alignment and over all adjustments.
Been digging through posts here about the same issue. Seems some were able to correct the issue with either sway bar kinks or adjusting control arms. I'll give it a shot, process of elimination. Thanks for your input.
Sent from my SM-G960U using WAYALIFE mobile app
If you’re talking about a lean to one side or the other (almost always a lean to passenger in JKs), you can fix it with coil spring spacers. I put a 3/4” spacer over my rear passenger side spring and that leveled the lean.
I have a 3/4 spacer on reserve if the link replacements don't work out. It's just enough lean to drive me nuts!
