THSPARKMAN
Need Help.  This has probably been asked before but I'm going to ask again so sorry if this problem has been addressed already.  I have a 2011 Jeep Wrangler JKU w/ 3.8.
First let me start by telling you my problems.
* Sputtering, Struggling, Occasional Backfire, Occasional Red Lighting Bolt, Lack of Take off Power, Check Engine Light of course, just overall running / missing etc.
The most recent codes are as follows.......
PO305 Cylinder 5 Misfire and PO128 Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
Second let me explain what I have already done
1. Replaced the Coil Pack w/new.
2. Replace the Thermostat w/new (twice).
3. Replaced the spark plugs and wires w/new.
4. Replaced the Coolant Temperature Sensor (twice).
5. Replaced the EGR Valve w/new.
6. Flushed the Coolant and Refilled w.new.
7. Oil Changed w/new.
My next thoughts / things to change would be the 02 Sensors (but not getting that code) or the Catalytic Convertor. I'm not a super mechanic by no means but am thinking that let's say the cat is plugged on the passenger side that it could be pushing back into Cylinder 5 (hardest plug to access) that is causing the misfire code. Just wanted to see if I could get some advice from those that are more experienced with this type of thing before I go and spend the money that it costs for a new Catalytic Convertor. Thank-you all in advance for your help and advice.
