Jkzinger
Hi Guys. I removed my pinion nut and yoke to change my pinion seal and it looks like Dynatrac has a metal baffle covering the seal area. It looks like I need to pop out the baffle to get to the seal. Does anyone out there have any good advice on getting the baffle out without damaging it?
I could be wrong, but I'm pretty sure that 'baffle' is just part of the seal itself. Do you already have the new seal for comparison?
Thanks guys! I will track one down just in case. Gotta be cheap.
This guy kind of looks like it:
https://www.dennysdriveshaft.com/p3...pinion_seal_fits_dana_60_and_super_60_fr.html
I just removed one of those on a Ford 9” a week ago... I had even less space than you beween the pinion and the seal... I couldnt get get leverage with a screwdriver so I used a small puller and reversed the arm in the opposite direction (so the claws face outward).. The seal popped right off.
Seal in place:
Seal removed:
The puller was a small version of this.. rotate the claws outward:
Seal in place:
Seal removed:
