ssh6314
Looking for any insight.
So Jeep is having steering issues, it wanders around the road. If it's pulling left and I correct it right. It goes way to far right, even at low speeds. The steering isn't tight, it doesnt want to drive straight. It wants to drift around.
I've recently done a ton of work to it which I'll list below. I've had a full alignment and axel adjustment done at NR4X4. And am going back for them to recheck it in my hunt for a solution.
All new parts:
37 Pantagonia MTs
17in Dirtylife Beadlocks, 3.5in Backspacing
3.5 inch RK flex lift
RK front lower adjustable control arms
RK adjustable track bar
RK rear track bar bracket
RK sway bars F/R
Teraflex HD balljoints
Bilstien steering stabalizer
Alignment and axle adjustment
I'm at a loss for what could be causing it. But its scary to drive on the freeway at this point. The interstate construction where I live will bump and pull anything around while driving over it, and its 10x worse in the Jeep.
included a picture of the front end for a visual reference.
All new parts:
37 Pantagonia MTs
RK sway bars F/R
