ROAM
Hi everyone! I'd like to update everyone on the current development progress of the ROAM JL Stealth Snorkel : we're getting closer to production factoring but there are still a few updates/changes that we'd still want to make to the current engineering prototype:
Please note that although our JL Stealth Snorkel effectively functions as a JL Cold Air Intake, the primary function of our JL Stealth Snorkel is still to raise the intake point/location higher.
The ROAM JL Stealth Snorkel utilizes/retains the OE air intake filter assembly. Our JL Stealth Snorkel ties directly into the main airbox assembly with a replacement lower section and does not require the use of an aftermarket cone filter. ( The ROAM JL Stealth Snorkel still uses/requires a stock JL engine air filter - 68257030AA or a Wix WA10841 )
The large compartment under the main intake routing houses an air/water separator assembly and a counterweight actuated drain valve.
No drilling required; does not require drilling or cutting the hood for air access - every exterior panel modified is included as a complete replacement.
Includes an external/exterior snorkel duct (not pictured) that follows the passenger side A pillar upwards; attaches to the transition piece at the base (will update with pictures by the next revision). The ROAM JL Stealth Snorkel is designed to not be visible by the driver (when driving, on North American vehicles only) with or without the exterior snorkel duct installed.
With our JL Stealth Snorkel installed, you can still fold down your windshield, with or without the exterior snorkel duct installed.
Our JL Stealth Snorkel is designed with high airflow in mind: every tube and transition in the ROAM JL Stealth Snorkel has a larger cross section and will flow more air than the stock intake system.
TBA: The ROAM JL Stealth Snorkel is Made in the USA with carbon filled PTFE infused cross-linked polyethylene for the ultimate in strength and durability. (UV-stable Cross-linked Polyethylene with PTFE nodules infused with carbon, think of this as chopped carbon fiber and PTFE mixed into the Cross-linked Polyethylene as an additive rather than / instead of the Cross-linked Polyethylene covering a layer of carbon fiber)
TBA/Late Availability: Optional exterior colors for the exterior snorkel duct: In addition to a black exterior, other optional colors will also be available in limited runs.
TBA: A variant of our external/exterior snorkel duct (not pictured) will be compatible with a precleaner / pre-filter attachment (compatible with all pre-filters / precleaners designed for a 4" duct transition).
Uses all stainless steel and/or plated hardware for corrosion resistance.
