I kept hearing a noticeable clunking every time I would change steering direction and thought it was a worn drag link end as I tore the boot some time ago trying to get it off when swapping axles.  I tested all of the tie rod and drag link ends with channel locks and they are tight.  I narrowed down the clunk to the track bar joint at the axle side, its noticeably loud, check out the play in my video, I'm going to get a replacement ordered today.
Check out the the play in the flex joint, is that normal being that its rubber or should I replace that as well? Both bolts are torqued to spec.
These are the original joints that came on this bar roughly 8 years ago, they only have 15k miles on them, albeit hard miles.
