RESURECTIONJK
Looking for some insight on some trans issues.
I’m leaning towards a valve body issue but, not really sure how to test it or check it without taking it in to the stealership.
2014 JK. 5.13’s 37’s Auto trans (obviously) has just over 166k miles. I’ve been religious about services and fluid is in good condition as is its level.
Symptoms are:
I get a bit of a hesitation to shift from 2nd-3rd when climbing even a slight incline, RPM’s will nearly hit 6,000 and sometimes I’ve got to manually shift it. On occasion, when on the trail the engine will bog down enough to stall, when this happens the trans won’t go into gear after I re start the vehicle unless I go through all the gear selections. Has also happened in 2wd pulling into parking stalls but only a few times.
Jeep is properly programmed for gears and tire size.
Any insight is helpful.
Symptoms are:
