Hendu3270
Started experiencing DW a few weeks ago. There is no slack in any tie-rod ends or ends of the drag link, Trac bar is solid (or at least I can't budge when I'm under the vehicle). Wheel bearing have no play that I'm able to tell and prying up under the wheels shows zero play in the ball joints. The only thing that I don't think is normal is the tie-rod and drag link are not "tight". What I mean, is if I rotate one up, it will just fall back down under its own weight. Again, there's no play in them that I can tell, but I would expect them to be solid. With good tie rod ends, those bars would stay in whatever position I put it in, right?
