boardsurfer
Roof Top Tent
Yes I am, I have some Yakima aero bars that I’m going to use. I also have to build a Baja truck style tire carrier that I’m mounting on the front. I added a picture of the RTT from this year’s trip to Telluride
Sent from my iPhone using WAYALIFE mobile appView attachment 325342
Right on! Only reason I ask is that I’ve been running your stabilizing jack setup for years and finally scrapped it for several reasons. The weight and time of setup, and the play between mount and pipe mount. That play made for wobbly, squeaky nights in the RTT. Redesigned to those crank down A legs. Way faster deployment and solid as a rock. Something to consider. Great Pic!!
Yeah I didn’t think it would be as wobbly as it is with 4 jacks, but that was information I didn’t have until I had welded them on and at that point I wasn’t cutting them back off. Maybe I can find a urethane liner of some sort to get rid of some of the play*
Yeah, I didn’t anticipate it either, it’s not like it’s that rough, I mean we put up with it for years. I’ve added/removed/tweaked so much stuff as each year passes dialing it in. Part of the journey with these trailers to get them where you want them. If you do decide to change it in the long run here’s what I swapped to.
Two pairs of these:
BAL 23225 Set of 2 "C" Jacks with Handle - 25" https://www.amazon.com/dp/B002P2YTIA/ref=cm_sw_r_cp_api_i_T34UCbT8JCCKV
Two pairs of these:
BAL 23200 Foot Pads for C Jacks https://www.amazon.com/dp/B004OI21MY/ref=cm_sw_r_cp_api_i_p54UCbCH0RHC6
And a pair of these:
BAL R.V. Products Group 23205 Connector https://www.amazon.com/dp/B003VAYAPM/ref=cm_sw_r_cp_api_i_454UCb8K5R3HQ
Thanks for taking the time to send me the parts links, maybe some day in the future. For now I have to finish a couple of minor thing and get ready for both, the Toyota jamboree (going with my brother in law in his 80 series) and the Jeep jamboree in Amarillo
Thank you, out doing that right now View attachment 326294View attachment 326295
So how did u mount the tub to the frame did u bolt it down or weld it? Just curious im thinking of building one later down road.
