fastra21
Got my 4” enforcer and Kings installed! Gonna need to get the nitrogen set at 70psi
Front & rear driveshafts.looking into the 3 in enforcer stage 2 with draglink flip for my 2 door jk. What else would be considered neccessary with this kit? Ill probably go with the bilstein 5100's for shocks.
I just installed this kit with the 31/30 combo along with rockstars in the back. Regarding the front RS99931s I think you will be fine at full droop, just make sure you use the 3 inch bumpstop or they will bottom out at full compression.Been waiting a long time to be able to get this kit, but can finally say I’ll be enforced[emoji3]....Just ordered the 3” stage 1 with Rancho RS999331/RS999332.
Quick question regarding shocks - will I be ok with this set up. A friend of mine told me this will be ok but just worried because the shocks are listed for 4” lifts
Ok so after laying everything out I sorta got cold feet in installing (enforcer 3in stage 1 w/drag flip kit) this myself [emoji29] I called a couple of shops here in San Diego and I got quotes around $800 for lift and shock install, is that a reasonable price? [emoji389][emoji389]
$800 actually sounds fair. Did you get it writing, do you trust the shop, they have experience working on Jeeps?Ok so after laying everything out I sorta got cold feet in installing (enforcer 3in stage 1 w/drag flip kit) this myself [emoji29] I called a couple of shops here in San Diego and I got quotes around $800 for lift and shock install, is that a reasonable price? [emoji389][emoji389]
You can do it. Save your $800 and just take it 1 step at a time. It’s really not bad at all once you get rolling on it.
However, there is nothing involved you can't do yourself in your garage or driveway if you have any mechanical aptitude. For that $800 you can buy any missing tools you need and have a bunch left over. If your worried about downtime for your daily driver take it in stages, but really you ought to be able to do the whole thing in a weekend.
You didn't mention anything about your driveline. Are you getting a new driveshaft (recommended) or putting in exhaust spacers? Also, front shock relocation brackets should be added, especially with the RS9000XL
$800 is what I charge for the stage 1 with drag link flip. $1000 for stage 3 with the flip. It’s a fair price.
it does seem doable but the instructions says to weld the rear track bar bracket, which is something I cant do
in all honesty I didnt think I needed exhaust spacers and shock relocation brackets....and as for the driveshaft, I was planning on getting one in a month or two
