Looking for a couple pieces if anyone has a used set they aren't using. This is for a 3inch lift.
Front and rear trackbar relocation brackets
Extended brake lines
Extended sway bar links
Sent from my SM-G965U using Tapatalk
Thanks for the offer. I didn't think about brackets. No issues with a 3 inch lift? Any added benefit for going straight to new extended lines as far as articulation goes?I have rear brake line brackets if they would work for you
I have some old rock krawler sway bar links (2) sitting around no idea if they will adjust after sitting so long and don't have bolts for them if your interested
Will they fit on the rear?
Sent you a pm
That's true. I see they were quick disconnects, didn't know if they were different somehow.I believe front and rear don’t make much of a difference since some lift kits will have you swap the front links to the rear...
I'm on a budget so I can pass on cooler right now haha. I'll pm youThey drop the mounting point 3” but stainless break lines are cooler [emoji106]
You can have them if you want them
