Installed the backup camera. It was pretty straight forward with the hardest part being routing the camera wires with RCA plugs through the small holes drilled through the bumper.
Here’s the camera and harness:
I wasn’t sure if I needed this coupler, but of course I did. Picked up a pair at Walmart:
I started with plugging the harness into the back of the radio.
I followed the instructions in this link to take part of the dash apart and get access to the back of the radio:
https://wayalife.com/showpost.php?p=678054
I also got some good info from this link for doing the wiring and mounting the camera:
https://wayalife.com/showpost.php?p=453431
Next I wired in the power connector to the passenger side reverse light. A white wire with gray stripe is the power. Use a 12volt test light to confirm and don’t forget to have the key in the run position, trans in reverse with parking brake set. Test again with the trans in park and you shouldn’t have any power. I snipped, stripped and spliced in the camera power wire:
Attach the ground to the tailgate hinge bracket, connect the video cable and make sure everything works.
Drill the camera mounting hole through the plastic bumper cover using the hole saw supplied with the camera. The plastic cover is hollow in the middle so I used a 1/2” drill to make a hole through the second part and wallowed out the hole to make a slot. It was difficult to get the camera wires with RCA plugs through the bumper holes and a pry-bar was needed to get the wires over the metal part of the bumper.
After that struggle, I cut a small slit into the rubber drain plug and routed the power plug to the camera plug, connected and wrapped with electrical tape:
The video cable took the same route and continued up the passenger side floor, into the dash, up over the glove box an coupled to the radio harness. Add some electrical tape to secure the connections, tuck the remaining wire and your good to go.
Daytime:
Nighttime:
The LED lights really do a nice job brightening the area.
Total cost for this project was $42 and took about 4hrs to complete. The wife’s KK is next.
