rockabillyroy
So remember when the Chinese embargoes happened? Tire companies like Nankang had to find a way around it so they opened plants in other places. Lots of tires started coming out of Indonesia. GT aka Gaja Tungal and several others. Many of them use more nylon in their casings and narrower steel belts. Cheaper construction but could still meet speed ratings and handling indexes. They were however more prone to vibration problems and out of round conditions as well as tread separations and poor mileage. Long story short is cheaper materials and construction. Some of the things however can work well in off road applications where heat and speed ratings aren't as important. They make for pretty tough casings for semi truck and off road tires. Makes sense they might work out ok in the larger sizes for off road use. Smaller sizes with less cavity will be more affected by heat so while the might be ok for off road and short trips summer heat and freeway speeds will probably be their downfall. They are a mostly bias ply tire with enough steel in them to qualify as a radial.
AJ, it sure sounds like you know a thing or two.:thumb:
