I guess I'm a little confused. The initial Wayalife post would indicate that the big problem with the 44 axle shafts was the C-clip coming loose from the U-joint and that the axle shafts themselves were generally not the problem. The write-up then goes on to show how to install a full circle U-joint in an Alloy USA chromalloy axle. I had expected that the write-up would show how to install a full circle clip U-joint in the stock axle shaft as a preventive measure to make sure that the U-joint on the stock axle doesn't fall apart when the C-clip comes out. Is there no full circle clip U-joint for the stock shafts or, perhaps, the Alloy USA write-up was given as an example for how to do it on any U-joint axle?
All of that said, I'm impressed with the detail of the write-up.
Thanks
Edit - Didn't see the post about tack welding the caps until after I posted
Sorry for the confusion. To clarify, a lot of people make the assumption that axle shafts that have u-joints "in general" are weak based on their experiences with "factory" shafts. This is why a lot of them assume they need something like an expensive RCV shaft. Of course, their assumptions are wrong and I am simply pointing out that a more affordable axle shaft with u-joints that have full circle clips will get the job and for a lot less.
Great write up, especially for people who've never worked on solid axles front ends before like my self although most of the processes other than setting ring and pinion/backlash and shimming seem pretty straight forward it never hurts!
Also will they be making these for the D30's?
Honestly, I don't know for sure. We just picked up what we needed for our purposes. I do know they make axle shafts for the Dana 30 and they are available with u-joints that have full circle clips but I don't think the X-Joints are made for it or, at least not as of yet.
Great write up. I appreciate the fact you take the time to put this stuff out. Very clear instructions. Thank you.
Well, we just hope that videos like these can be of help to others.
