I’m not sure why people remove lines from a carb. It’s there for a reason. When I picked up the FC nothing was hooked up and it ran like shit.
Depending on the year, most of it is for emissions crap and if you have just one vacuum line leaking, your engine will run like shit. Of course, tracking down a leak on miles and miles of vacuum lines can be near impossible at times. If you remove the emissions crap and cap off most of the ports, you'll have a engine that runs nicely.
Mine was not emissions lines, it was vac lines for the carb to work properly, same way with the line to the exhaust manifold, it helps with cold starts.
As long as the vehicle starts, the air heats up quickly and pumps through that hose into the air cleaner. Inside that air cleaner is a metal door that opens allowing the hot air in. Once the engine reaches a good temp, the door closes and no longer needs the hot air and rather just sucks ambient air from outside through that snorkel opening. I'll try to find a diagram. Just like a lawnmower runs like shit when it's cold out, this feature helps the engine run well faster and sooner. Hot air atomizes fuel way faster than cold air.
Were you able to get Tina behind the wheel over the weekend? Looks like a fun project and not too over the top as you stated. [emoji106]
You’ve never had a carbureted motor before? Damn, carbs are that old already
The ... nut .... is way bigger than I thought.
No she didn’t. She’s scared of the 45 year old brakes. Lol
Got new ball joints, radiator hoses, gas tank cap and that heater hose ordered today. Tried picking up some bearings and seals for the front end but there were two part numbers so I need to pull it to see which it is. I’ll pick those up tomorrow.
Brakes as old as me. Nothing to fear.
Where are you finding all the parts for a ‘75?
What a pussy, he has a dual master. He’ll be fine. I drove my M38A1 around with no brakes and it already killed a guy.
Grow a pair...
