The first big Project on the Jeep was to sleeve the front axle. Yes I am sticking with a dana 30 on the front. I haven't had any real issues with it other than 1 cracked cv and one busted boot. As I want 33s max and I don't "wheel" the jeep all the heavy very often, I didn't think that a dana 44 would be worth it. So apart the 30 came.
Oh but first Yes new wheels, Vision Manx that are 16x8. They fit perfectly and look awesome. But I have since rock rashed every single rim, eh I know I would.
Cover and fluid out
Axles and hubs out, brakes off.
Took the Tie rod off to access the carrier. And found the ball joints were Shot, time to fix that up with upgrades.
Mmm factory LSD, I have had great luck with this and I have no want to replace it.
Back to work to flatbed and do a camper install on the old Maxtrax F250
Now back to pounding the sleeves into the axle. It was welded around the outer end, and I drilled 8 holes in the long tube and 5 in the short tube to button weld the sleeve. So it is safe to say its not moving.
Back together with a fresh coat of paint which I didn't notice until halfway done that it is actually a dark brown. (Facepalm)
New beefy 1/4" over from chassis unlimited to match the rear diff.
And all back together and ready to take a trip.
Sent from my VS996 using Tapatalk
