It’s an AEV Bumper so you may have to use their Winch plate. I don’t think it’s too expensive. I can’t speak to a 12k but I had a 10k in mine no problem.
Actually i cant find an email to ask a question on their website. so may have to call them.
If anyone has direct knowledge let me!
I have the SB 12k with the rugged ridge hybrid stubby. I like how it’s out of the way.
So i spoke with aev. Their mount plate for this bumper is $285 (exorbitant!) and is only rated for 10k lbs. Neither are acceptable in my book. It's not even really the money, imho. It's more the fact i can buy an entirely new bumper with a built in mountfor that price. And 10k lbs is unacceptably low load rating.
Does anyone else have experience with internal mount plates (non-aev) on this bumper? There are so many configurations out there I'm just trying to find something that will work with my setup without too much of a headache...
I would pull up the instructions for AEV Part #: 10305060AB and see if there are any obvious reasons it would not work with your bumper. It's $145 at qtec.
10k is not a low rating for JKs. I'd be surprised if more than 1% of the folks on here ran anything bigger than a 10k winch on a JKU.
You "can" buy another bumper with a winch plate for $285 but you'd be looking at some chinese POS, IMO.
Try this thread: https://wayalife.com/showthread.php...Plate-and-Zeon-10S-install-on-10A-X-HR-Bumper
Not sure if it will work, but might give you some ideas.
Good to know. I'll keep that in mind. A friend said if the plate is almost 300 may as well buy a bumper.
I'll explain my "need" for a 12k lb winch. My gf is a terrible driver and owns the largest hybrid suv on the market. I live in the boonies in indiana and its winter time. She will be in a ravine by the end of winter, I'm guessing. I'd like to be qble to yank her out.
I also burn firewood for heat. It would be awesome to be able to pull some trees out of my woods instead of having to clear a spot to dropped trees.
Also cause why the f not?
I know i can use a block or other methods to reduce the pull force required by the winch. But I'm trying to make sure i have more than adequate winchability.
Or maybe weld some reinforcement onto the plate?The winch plate is probably rated the same as the bumper. Use a snatch block like you mentioned or buy some 7” x 2” x 3/8” channel and build your own.
Honestly with a snatch block it will never see 10k. Still need to check a link or two but may install the one for 10k and mount my winch. The 10-12k smittys have the same footprint.
From what i read the winch plate itself attaches to the frame. I may be wrong but if so the bumper rating shouldn't matter?
I’m sorry it the rough country bumper. You will need a relocation bracket for brake pump.
