DIY Trail Vise
klungly
I'm too cheap to buy a trail d-vise so I tried to make my own. Here's what I came up with. First I drilled 2 holes in some 2" square bar stock. The radius's were milled with a rotary table. Then I milled them to the thickness I wanted and milled slots for the jaws to mount into.
I used a piece of .250 wall 1.5" square tubing for the sliding portion and milled it into a channel.
I made a nut for the lead screw and tapped it with a 5/8-8 acme tap. I welded a 15/16th nut onto the end of the lead screw to give the ability of using a crescent wrench in a trail bag. I put the nut inside the channel inside a piece of. 180 wall 2" square tubing to check for fitment.
I had started a fixture to be used for notching tubing with my rotary table and mill. I finished it by drilling and taping 2 holes. I needed to use it as a V block to make another fixture for cutting the knurl in the jaws.
I cut the jaws apart from each other after being worked on as one piece and drilled a hole in the moving jaw for the lead screw.
Once all the pieces had been machined, I started welding everything together. The nut was plug welded into the main body.
Looks awesome! Must be nice being able to create things such as that [emoji106]
Thank you
That’s awesome man! Great work
Thank you
Great work! Always feels good to make your own stuff when you’re able to.
Thank you
Nice work! Tedious work knurling the jaws I bet.
Thank you. It was tedious but it came out great and I think it was worth it.
Dude's got skills...back in the day I would fab our own specialty tools in our shop...but now, I'd just pay someone to weld a vise to stock to fit my receiver hitch, or get the one from Mac's
Your's came out nice...
Great work!
It sure is nice to have the skills and tools to build your own stuff.
Thanks for sharing
Thank you
Wow clean work man!
Thank you
Great work!
Thanks for sharing
Thank you
Amazing skills!
Thank you
Great work! I always tell my wife that my weekend labor rate is $100/hr so I don't do projects around the house unless it saves me that much. Of course this rule doesn't apply to Jeep projects, I will work all weekend and brag that I saved $100 [emoji849].
Ha! I'm the same way...
"You've spent the whole weekend in the garage!"
"But I saved $150!!"
