For those of you who've been wanting one of the new and improved Hitch Stingers that I designed and have made for all my Jeeps, I'm happy to announce that I just got a batch in and they are now available for purchase!
The Hitch Stinger is designed to help protect your Jeep's spare tire from catching on ledges and obstacles that would otherwise cause significant damage to your tailgate. Angled up at 20° and right from the hitch receiver, the Hitch Stinger provides maximum departure angle and reduces any hits that it may receive into glancing blows. In addition to offering 14" of protection, the Hitch Stinger also comes with 2 mounting positions so that it can be used with different tire carriers, tire widths and wheel back spacing. The Hitch Stinger is available in bare steel or in an optional semi-gloss black powder coat. Last but not least, the Hitch Stinger is MADE IN THE USA by a veteran owned shop and natives of Carson City, NV, Sean Weed and Josh Ostler.
CLICK HERE TO BUY A HITCH STINGER
NOTE: Due to different back spacing on wheels, a 37" spare tire mounted on a JL or JK Wrangler tailgate MAY require a riser bracket to be installed in order for it to clear the HITCH STINGER.
The HITCH STINGER
Here are a few shots of what the HITCH STINGER looks like in a semi-gloss black powder coat. I should note that the spare tire you see is a 37x13.50 Cooper STT Pro mounted on a KMC XD231 beadlock wheel with 4.75" of back spacing and attached to a JL Wrangler factory tailgate using an LoD riser bracket.
Shot of what the HITCH STINGER looks like in a standard bare steel and in an optional semi-gloss black powder coat.
These shots show the new and improved HITCH STINGER sitting on top of my old stinger. As you can see, the new design offers the same protection to the spare tire while providing a significantly greater amount of departure angle.
As you can see here, the point on my old stinger that took the most abuse sits approximately 2.5" lower than the new and improved HITCH STINGER.
Here's a couple of shot of the HITCH STINGER mounted in the extended position and being field tested.
And finally, because I know people need to see pics to believe it, the HITCH STINGER is made to work on a JK as well.
Please let me know if you have any questions.
The HITCH STINGER
