This sounds awesome. Add me to as a maybe. Hard to say this far out just yet but saw some video of this place. Wow. Looks incredible.
That’s the way you have to do this part of 15. This is midway, tuck your mirror and turn into the wall. He is past the big rock climb that turns most people away, it looks nastier than it is. He’s got another rock climb coming up that doesn’t look as bad, but it’s very slick rock coated in lots of rubber.
Added! Looking forward to meeting you.Add me. 35s locked front and rear 4” lift, I have been there several times.
This was back in the spring,is getting rutted and under cut pretty bad.
That is the trail we’re I exploded my rear locker! To much skinny pedal!
Same v notch. It’s pretty deep.
Are you able to bridge the gap with tires on each side? Or do you have to run it?
Holy crap now that's a tight squeeze.
When it’s wet I can’t get the rear tires to climb out. So just ride the notch. Dry it’s usually not a problem. Wider wheels with less offset will keep you off the side. The guy I was with had atx slabs and he didn’t rub his hardtop
Sent from my iPhone using WAYALIFE mobile appView attachment 309940
KMCs XD-229 machetes, not slabs, but same point with the offset.
I’m kinda not liking 15 because of the notch.
