Hello again...
I had to simplify my other post so I just started a new one.
After installing a ton of new parts including Oliver shafts I had my caster out of wack, I pulled the front shaft and all of my vibration went away.
Shaft was reinstalled.
I have my caster at 90* with the intention of trying 91/92* next but now I’m almost out of adjustment on the upper arms.
It took me 3 adjustments to get from 85deg down to 90. I put everything back together after each adjustment and drove the Jeep.
85 heavy vibration at higher speeds
Alignment guy got me to 87 with little improvement but move my toe in a hair.
I got the caster to 88 and finally 90 but I still have a pulse vibration on the highway.
Will 2* make it all better or should I have the driveshaft checked for balance? It’s new and installed correctly.
Current setup.
Current setup.
