sinawalli
My Nitto Ridge Grapplers 285-75-17 measure 33.125" with about 32psi in them.
Ok so if my lift says maximum 34” tires, do I buy a tire that says 34” on the side or one that’s about 1.5” taller (then my he side specs) like 35”-35.5” knowing that in reality it will be smaller?
Can someone tell me what would be the real size of a Toyo Open Country AT2 Extrem in 285/75R18 and in 295/70R18?
Thanks a lot
	I’ve been searching for a few weeks and no luck, can anyone tell me the height of 285/70r17 Mastercraft MXT’s?
According to their own website, their 285/70R17 is 32.91 inches in diameter (off of the vehicle with no weight on it). This is nearly identical to every other 285/70R17 tire out there. So with the weight of the Jeep on your tire, you'll likely have a total height of slightly under 32 inches (you can find several of that size tire in this thread).
http://mastercrafttires.com/Tires/Light-Truck/Courser-MXT.aspx
Lol thanks for the PowerPoint. As stated in my post I’m aware what the specs say but this thread is for real world actual measurements and that’s what i’m Searching for.
And, out of over a million posts on the forum, apparently no one here runs them. That could be a good tip-off. [emoji41]
